87/88 T-BIRD TURBO COUPE PART NUMBERS
Information compiled by Chris Sheffe - Bryans Road, MD
| To download a copy of this in MS Word 2003 which has better formatting, click here |
Front Bumper
E7SZ-17D957-B Cover, face bar W/turbo 537.69
E7SZ 17C829-B Pad, horizontal red 62.22
E7SZ-17D890-A Stripe tape Turbo 16.30
E7SZ-17A385-B Bracket,license W/turbo 23.93
E7SZ-17757-C Face bar W/turbo 134.98
E7SZ-17E814-B Kit,reinforcement (includes side brkt.)W/turb 40.36
E7SZ-17C947-A Support,cover 26.07
E7SZ-17754-A Absorber,impact R/L 163.08
E7SZ-63001A06-A Deflector,air W/turbo 27.88
Grille/Front Panel
E7SZ-8190-B Panel,front W/turbo 298.23
E7SZ-8213-B Emblem 24.73
Front Lamps
E7SZ-13008-A/B Lamp Assy. R/L $ 161.02
E7SZ-13007-A/B Lens, head lamp 46.12
E7SZ-13118/9-A Housing,adjustment R/L 28.23
E5LY-13N021-A Bulb & retainer R/L 20.70
E7SZ-13N019-A Retainer,bulb R/L 3.75
E7SZ-13200/1-C Parklamp W/turbo 42.70
F5AZ-13466-A Bulb,parklamp 4.76
E7SZ-13200/1-A Lamp,side marker 96.49
F54Y-13466-A Bulb 8.77
E7SZ-15A201-A/B Lamp,cornering R/L 26.83
F5AZ-13466-A Bulb 4.76
E7SZ-15200-A Lamp,fog R/L 127.72
E7SZ-15L203-A Lens,fog lamp R/L 55.93
Cooling
E8ZZ-16138-A Core support $190.13
F0ZZ-8A281-A Reinf,support R/H 45.38
F0ZZ-8A281-B Reinf,support L/H 41.63
E7SZ-8005-B Radiator Man. trans. 4Cyl. 325.98
E7SZ 8005-A Radiator auto.trans. 4Cyl. 380.08
E6LY-8100-A Cap,radiator 6.54
E7SZ-8A080-A Tank,coolant recovery4Cyl. 25.72
E7SZ-8146-A Shroud,fan 4Cyl. 171.23
E8SZ-8260-E Hose,radiator upper 4Cyl. 18.45
E8SZ-8286-D Hose,radiator lower 4Cyl. 33.57
E7SZ-8600-B Fan blade,cooling W/4 blades 35.80
E7SZ-8600-A Fan blade,cooling W/7 blades 44.98
E6FZ-8K621-C Motor,fan 4Cyl. 76.52
E7SZ-8509-A Pulley,water pump 65.72
E8SZ-8620-J Belt,drive 28.97
E6ZZ-8501-A Pump,water 4Cyl. 84.28
Electrical
E7SZ-13832-B Horn Assy. W/turbo 37.37
E9FZ-12106-A Cap,distributor 13.86
E9TZ-11450-B Switch,solenoid (starter) 19.62
F3SZ-10346-A Alternator Assy. 386.48
E6DZ-10344-E Pulley 15.00
E73Z 10310-A Fan,Alt. pulley 53.41
E8SZ-8620-J Belt,Alt. drive 28.97
Daco part No. 610K6 20.99
E73Z-10316-A Regulator,voltage 57.25
E7SE-68209-AA Tensioner,Alt. side (flat wheel) Dayco part No. 305205 66.99
Engine
E4TZ-6312-A Pulley,crankshaft 4Cyl. 78.90
E7SZ-6038-A Insulator,engine mount R/H 4Cyl. 89.64
E8SZ-6038-A Insulator,engine mount L/H 4Cyl. 72.28
E8SZ-6030-A Brkt; E-mount R/H 21.52
E7SZ-6031-B Brkt; E-mount L/H 46.05
F2SZ-6068-A Insulator,rear (Trans. mount) W/man. trans. 81.86
F2SZ-6068-B Insulator,rear (Trans. mount W/auto. trans. 77.97
F1DZ-6019-B Cover,front (1988) 4Cyl. 126.08
E43Z-6019-A Cover,front (1987) 4Cyl. 120.88
E7SZ-6675-B Pan,oil W/low oil sensor 4Cyl. 101.58
E7RY-6675-B Pan,oil WO/low oil sensor 4Cyl. 116.67
F1ZZ-6710-A Gasket,oil pan 33.09
E6LZ-9A407-A Pump,oil 281.97
Exhaust
E3ZZ-9430-A Manifold,exhaust $ 138.27
E8SZ-5E212-B Converter,catalytic 550.00
E7ZZ-5230-C Muffler & Pipe 161.97
Air Conditioning
E7LY-19712-A Condenser $ 204.49
E6TZ-19703-b Compressor 287.17
E6SZ-19972-G Hose,compressor 122.63
E8SZ-8620-G Belt,drive 19.18
Dayco part No. 360K6 11.99
E7SE-68209-08 Tensioner,A/C side (grooved wheel)
Dayco part No. 305206 74.99
E7SZ-16612-B Panel.hood $ 475.83
E7SZ-16C630-A/B Scoop,hood R/L 50.25
E8SZ-16796/7-A Hinge L/R 48.73
E6DZ-16700-A Latch 24.53
E7SZ-16892-A Catch,auxillary 13.87
E3SZ-16747-A Support,latch 11.42
E7SZ-16918-A Cable assy. release 31.31
E3SZ-16740-A Pad.hood 12.48
E8SZ-16738-B Insulator,hood W/turbo 87.87
GG391 385595-S Retainer,insulator Pkg. of 16 4.64
NN180 386553-S Retainer,insulator Pkg. of 10 2.50
Front Suspension
F1ZZ-1102-B Hub & Rotor R/L $ 82.81
DOAZ-1217-B Cup,bearing outer R/L 3.70
D8BZ-1201-A Cup,bearing inner R/L 4.28
E7TZ-1261-A Bearing,outer R/L 15.93
DOAZ-1201-A Bearing,inner R/L 11.55
FOZZ-1190-A Seal,grease R/L 6.65
E5LY-2K004-A Shield,splash R/H 16.68
E5LY-2K005-A Shield,splash L/H 14.60
F1ZZ-2B120/1-A Caliper,brake R/L 67.96
E5ZZ-2078-B Hose,brake R/H 42.67
E5ZZ-2078-C Hose,brake L/H 50.22
E7SZ-2310-B Spring,coil (order by spring ID) 55.27
E7SZ-18124-C Absorber,shock R/L 199.02
E7SZ-18B012A Actuator,shock (auto ride control) 96.05
E7SZ-18A161-B Brkt,shock R/L 140.35
E0SZ-3B391-A Plate,camber adjust R/L 9.02
E7SZ-3105/6-A Spindle R/L 234.03
E7SZ-3078-A Arm Assy; lower control R/H 85.70
E7SZ-3079-A Arm Assy; lower control L/H 88.90
E2BZ-5482-D Bar,Sabilizer Hvy. Duty 125.27
E7SZ-5025-B Member, Front cross 566.88
Front steering linkage/gear
E5DZ-3L547-A Gear Assy,steering W/handling pkg. 329.12
E3SZ-3548-B Housing,steering gear W/handling pkg. 143.17
E5SZ-3D517-A Shaft/control Assy. 113.92
E5DZ-3575-B Rack, W/handling pkg. 63.15
F6SZ-3280-CA Rod, connecting R or L 24.12
E69Z3332-A Boot,dust R or L 21.67
E2SZ-3A130-A End, tie rod R or L 61.62
E8SZ-3A674-A Pump Assy; W/O pulley 314.70
F0CZ-3A697-A Reservoir, W/turbo 28.98
D4ZZ-3A733-A Pulley,pump 37.90
EZSZ-3600-C Wheel,steering W/turbo W/O speed control 169.67
E7SZ-3600-D Wheel,steering W/turbo W/speed control 373.97
E7SZ-3600-B Wheel,steering W/turbo W/speed control W/leather wrap 401.77
E3SZ-3530-B Cover,lock housing upper W/console 15.68
E3SZ-3530-F Cover,lock housing lower W/console 15.68
E2LY-3511-A Housing,lock upper 24.80
E83Z-3511-A Housing,lock lower 24.80
E6SZ-11582-A Cylinder,ignitionlock W/keys 29.96
F2BZ-11572D Switch, ignition 5.93
E3DZ-3514-C Jacket,W/floor shift 110.92
E2SZ-7212-A Tube ,shift 90.58
E5DZ-3524-A Shaft,steering upper 322.33
D9BZ-3B676-B Shaft,steering lower 182.48
E0SZ-3A525-A Coupling.shaft 11.63
E3SZ-6303100-A Glass,windshield Ford,clear 344.29
F0LZ-6303100-A Glass,windshield Ford,tinted 781.47
DW00949CLN Glass,windshield NAGS,clear 760.30
DW00949GBN Glass,windshield NAGS,green/blue shaded 781.50
E7SZ-6303144-BA Moulding,reveal upper black 52.91
E7SZ-6303136/7DA Moulding,reveal side black 54.35
E4SZ-6303148-A Moulding,reveal lower black 86.55
E3SZ-6303606-A Moulding,inside garnish upper W/O electronic inside mirror 24.75
E6SZ-6303606-A Moulding,inside garnish upper W/Auto lamp dimmer 19.02
E5SZ-6303598-A Moulding,inside garnish R/H side 41.60
E5SZ-6303599-A Moulding,inside garnish L/H side 37.87
E65Y-17700-A Mirror,rear view manual 53.82
F19Z-17700-A Mirror,rear view power W/O dimmer sensor 272.70
E80Y-17700-B Mirror,rear view Power W/dimmer sensor 282.18
E7SZ-6304104-B9B Viser,sun W/Illuminated mirror R/H Blue 210.97
E7SZ-6304105-B9B Viser,sun W/illuminated mirror L/H Blue 177.98
F6AZ-17528-EA Blade assy; wiper R or L 8.77
E4SZ-17526-A Arm,wiper R/H 19.42
E4SZ-17527-A Arm,wiper L/H 26.32
E7SZ-17508-A Motor,wiper 236.02
F4ZZ-17618-A Reservoir,washer W/O low fluid sensor 36.27
F4ZZ-17618-B Reservoir,washer W/low fluid warning 34.90
E0AZ-17664-A Pump,washer 24.30
E4SZ-17603 Nozzle,washer R or L 10.17
INSTRUMENT PANEL
E7SZ-6304320-B Panel,instrument (order by year and model Application ) 598.43
E7SZ-66044D70-A Panel,cluster finish W/O woodgrain 115.30
E5SZ-63044D70-C Panel,finish(center dash) W/O split bench Order by application 68.12
E5SZ-6306010-A Glovebox 100.15
E7SZ-6306024-A Door,glovebox Blue order by color 78.22
E5SZ-6306050-A Hinge,glovebox 6.18
E5SZ-6304645-A Panel,lower extension Black order by color (under steering column) 15.07
E7SZ-63045A36-B Panel,console (base) W/floor shift 315.00
E5SZ-6304567-C Panel,top finish (boot retainer) M/T 4Cyl. 61.73
E5SZ-6304567-B Panel,top finish (boot retainer) A/T 4Cyl. 61.73
E7SZ-63044E50-A Panel,center finish (switch panel) 35.18
E7SZ-6304722-G Insert,center panel (order by application) 8.40
E3SZ-6306010-B Glovebox 23.38
E7SZ-6306024-G Door,glovebox Blue order by color 65.95
E7SZ-63045E24-A Panel,finish rear W/light 46.32
E7SZ-63045E24-B Panel,finish rear W/O light 21.63
Seat
E7SZ-6361704-A Track,seat driver R/H 27.17
E6SZ-6361705-A Track,seat driver L/H 57.68
E6SZ-6361704-A Track,seat passenger R/H 27.17
E7SZ-6361705-A Track,seat passenger L/H 27.17
E6SZ-63611A72/3-F Belt,front seat R and L side Blue 84.40
E7SZ-63613884-F Belt,rear seat R/H Blue 73.13
E7SZ-63613885-5 Belt,rear seat L/H Blue order by color 73.13
Door Exterior trim
E7SZ-6320550/1-BA Moulding,window trim front black R & L 34.45
E7SZ-6320846/7-BA Moulding,window trim upper black R & L 40.00
E7SZ-6320554/5-BA Moulding.window trim rear black R & L 29.27
E7SZ-6321452-D Moulding,belt W/turbo R/H includes W/S 50.65
E7SZ-6321453-D Moulding,belt W/turbo L/H includes W/S 33.18
E7SZ-6320938-BP Moulding,lower wide type black/red R/H 152.78
E7SZ-6320939-BP Moulding,lower wide type black/red L/H 134.95
E7SZ-6321140/1 Moulding,door rear R&L 28.42
E7SZ-6320910-BSP Moulding,door edge R or L 12.67
Tape,stripe see tape stripe section
E7SZ-17682-B Mirror,rear view power remote R/H 212.25
E7SZ-17682-C Mirror,rear view power remote L/H 201.65
Door interior trim
E7SZ-6323942-BLG Panel,trim W/power windows R/H blue 401.38
E7SZ-6323943-BLG Panel,trim W/power windows L/H blue 401.38
Order by trim code
E7sz-6322666-k Strap,pull W/O backing plate 22.18
E7SZ-6322666-B Strap,pull W/backing plate R/H 50.75
E7SZ-6322667-B Strap,pull W/backing plate L/H 55.45
E7SZ-6324144/5 Armrest L&R Blue order by color 57.87
F13Z-1808-A Speaker,radio order by year & model application 32.78
Door Hardware
F0FZ-5821812/3 Latch R&L 38.30
E7SZ-6322050-J Cylinder & Key black Cyl. W/turbo R or L 55.58
E3FZ-6122404/5 Handle,outside R&L 38.53
E7SZ-14A626-A Pad,keyless entry 218.98
E7SZ-63218/9-A Handle,inside L&R 16.30
E3SZ-6322800/1 Hinge,upper R&L 20.65
E7SZ-6322810-A Hinge,lower R/H 35.92
E7SZ-6322811-A Hinge,lower L/H 43.30
Door glass and parts
E7SZ-6321410/1-B Glass,front door Ford tinted R&L 457.65
DD07196-7GTY Glass,front door NAGS-green R&L 457.65
E8SZ-6321596-A Run,upper R/H 85.88
E8SZ-6321597-A Run,upper L/H 104.08
E8SZ-6321456-A Weatherstrip,belt RorL 22.38
E7SZ-63222A00-A Run,hinge side R/H 20.40
E7SZ-63222A01-A Run,hinge side L/H 36.03
E7SZ-6323608/9-A Regulator,Power window L&R 131.30
E7SZ-6323394/5-A Motor,drive L&R 148.95
E7SZ-6323230-A Arm,equalizer R or L 7.62
Overhead console
E8SZ-63519B42-C Panel,roof console Blue order by color 171.87
E6SZ-13734-A/B Lamp;interior R&L 28.48
E80Y-54502A82-A Glass,sunroof Ford 1047.80
DR06990 Glass.sunroof NAGS N/A
E8SZ-63519A02-ANB Panel,trim opening Blue order by color 312.50
E8SZ-15790-A Motor,sunroof 385.61
E6SZ- 6350998-A Shield,roof opening 95.42
E6SZ-63502C12-A Weatherstrip,panel 32.10
E6SZ-6351070-A Rail,sunroof 732.63
E6DZ-54502P68/9-A Support,roof deflector R&L 19.23
E6SZ-63500A26-A Deflector,air 90.98
Back window
E7SZ-6342006-C Glass,back window Ford tinted 1987 822.47
E7SZ-6342006-A Glass,back window Ford tinted&heated 1987 1661.99
E8SZ-6342006-B Glass,back window Ford tinted 1988 822.47
E8SZ-6342006-A Glass,back window ford tinted&heated 1988 1124.01
D807202GTN Glass,back window NAGS-green heated 1987 1662.02
D807515GTY Glass,back window NAGS-green heated black Moulding 1988 2202.15
D807516GTY Glass,back window NAGS-green non-heated Black moulding 1988 1532.50
E7SZ-6342430/1-BA Moulding,reveal upper black R&L before 12/87 35.48
E7SZ-6342430/1-BA Moulding,reveal lower black R&L Before 12/87 30.35
E7SZ-6342492/3-BA Moulding,reveal side black R&L Before 12/87 26.05
E8SZ-6342410-A Moulding,inside garnish paint to match From 12/87 19.82
Interior trim rear
E7SZ-6331012-A1B Panel,trim (side) R/H Blue order by color 85.92
E7SZ-6331013-A1B Panel,trim (side) L/H Blue order by color 95.45
E7SZ-6331718-A1B Pad,armrest R/H Blue order by color 35.27
E7SZ-6331719-A1B Pad,armrest L/H Blue order by color 35.27
E7SZ-6331076-AZB Panel,trim finish R/H Blue order by color 67.73
E7SZ-6331077-AZB Panel,trim finish L/H Blue order by color 67.73
E7SZ-6352018-A1B Panel trim upper R/H Blue order by color 58.77
E7SZ-6352019-A1B Panel,trim upper L/H Blue order by color 58.77
E7SZ-6346668-A6B Panel,pkg. Tray Blue order by color 38.65
E9ZZ-18808-A Speaker,radio standard 43.72
E9OZ-18808-C Speaker,radio W/premium sound 54.62
E7SZ-6329710-E Glass,quarter Ford R/H,W/O black frame 740.39
E7SZ-6329711-E Glass,quarter Ford L/H,W/O black frame 780.75
E7SZ-6329710/1-F Glass,quarter Ford R&L W/black frame 757.13
DQ07-214/5GTY Glass,quarter NAGS solid black band L&R
W/black frame to mid 1987 757.00
DQ07422/3gty Glass,quarter NAGS dotted black band L&R
W/black frame from mid 1987 757.00
E7SZ-6329796/7-AA Moulding,outside front R&L .49
E7SZ-6340110-A Lid,luggage paint to finish 522.50
E7SZ-6342528-A Plate,name “Thunderbird” 18.92
E4SZ-6342528-A Plate,name “Turbo-Coupe” 18.92
F33Z-5443200-A Latch 24.95
E0MY- 6643252-A Plate,striker 12.17
E7SZ-6343507-B Cylinder,lock W/keys Black W/turbo 43.98
E7SZ-6342700-A Hinge R/H 45.40
E7SZ-6342701-A Hinge L/H 49.67
E7SZ-6344890-A Bar,torsion R/H 14.00
E7SZ-6344891-A Bar,torsion L/H 12.80
E7WY-6643720-A Weatherstrip 48.95
E8SZ-9002-A Tank,fuel 277.66
E7AZ-9030-B Cap,filler 10.43
E7SZ-9034-A Pipe,filler 51.43
E6sz-9275-B Gauge,tank unit W/O electronic cluster 79.68
E8SZ-13404-A Lamp assy. Tail light R/H 283.76
E8SZ-13405-A Lamp Assy. Tail light L/H 278.89
E7SZ-13450/1-A Lens,tail light R&L 175.09
E7SZ-13380-C/D Reflector,lamp inner R&L 42.78
E7SZ-13380-A/B Reflector,lamp outer R&L 15.89
E7SZ-13A495-A Seal,rear lamp center or outer 10.12
C8TZ-13466-A Bulb,tail lamp R or L to 1/87 1.47
F4CZ-13466-A Bulb,tail lamp R or L from 1/87 3.28
C3DZ-13466-A Bulp,back-up lamp R or L 1.52
E8SZ-13A613-A Lamp Assy. 72.33
E7DZ-13A621-A Bracket,lamp 3.76
D7TZ-13466-A Bulb 1.52
E7SZ-17K835-A Cover,bumper paint to match 125.35
E7SZ-17C829-C Pad,bumper red (accent piece) 62.22
E7SZ-17906-A Bar,face 134.33
E7SZ-17D942-A Reinforcement,bumper cover 34.45
E7SZ-17787-A Absorber,impact R or L 135.02
I compiled these numbers using a body shop crash guide of the mid to late 90s vintage I left the prices in so that you can see what they cost from Ford, incase you can find some NOS parts or to use as a guide at places like Carlisle when the venders star bringing them to the shows.
Ford numbers the parts that have a right or left application by the last number in the body of the part number such as E8SZ-13404-A for the right hand tail light the left side would be E8SZ-13405-A remember that the right side number will always be the even one of the two. Another way that they indicate left or right is by the letter at the end of the number E7SZ-13380-A for the right side and E7SZ-13380-B for the left side.
When they print some of these books to save space they will only print one base number to cover both sides such as E7SZ-6321140/1 the 40 being the right side and the 41 being the left followed by a R/L. In the text I have placed the color for that particular P/N in bold type Blue this simply means that the part number that appears is for that color only and you should use this number as a reference but should order the number W/the correct color designation at the end.
One final thing is the part number (this is what Ford uses for ordering purposes) may not be the same as the number that appears on the part, this number is the casting or engineering number it is close but may or may not be the same also do not confuse the casting number with the date code which often appears on things like sheet metal.
